Tires Vibrate At Low Speeds...
I just had new Firestone front steers installed. Everything seems to be fine when driving except for at about 30 mph the truck vibrates pretty bad, at around 35 mph the virbration goes away. I did not have the front end aligned, and the truck does not appear to pull to one side or the other when I let go of the wheel. This appears to be on the driver’s side. Any suggestions?
Thanks Neckster |
It could be many things other than the steers. I would think a mechanic could check out the front end pretty quick and determine if something was wrong with the front end and then go from there. Could be the drive shaft or something along those lines.
I have a Mustang that vibrates at 62mph. Bugged me for a long time until the dealer told me it was the convertible top. With the top down, no vibration. Just happened to hit the harmonic frequency at 62. |
Re: Tires Vibrate At Low Speeds...
Thanks Neckster OK, jack up the suspect side of the vehicle (first), then kneel down and look just across the top of the tire tread... now spin the tire, does the tire wobble back and forth, or up and down? Also, there should be a raised line on the tire that runs parallel to the edge of the rim... again, spin the tire and watch that line, does the line disappear under the rim? That can identify an improperly mounted tire. Also, watch the wheel/wheel mounting as well. Improper torque sequence, debris on the hub flange, etc can cause the wheel to wobble. If wheel alignment was the problem, it would have existed (???) before you replaced the tires. Wheel alignment rarely causes vibration... it will often damage a tire which will in turn vibrate as a result of the damage. New tires (even defective new tires) do not commonly cause pull. In H/D trucks, pull is most often caused by rear axle alignment (dog-tracking, or scrub). Unless funny/odd wear patterns show up on the front tires. Remember, if the vibration wasn't there before the tire replacement, the tires are most likely the cause. I wouldn't be so sure which side it's on... that can be very misleading. |
Thanks Bob H...
Very good information Bob, and thanks for the reply. When I bought the truck the front tires were not in too bad of shape. The drivers side tire was cupped on the out side, but still had a lot of tread on it. The passenger side was in good shape and was not cupped.
I did not watch the shop install the tires, and do not know if thet were balanced. The virbration is noticed mostly on the same side as the tire... drivers side, and is noticed in the drivers door and mirror. Like I said it's only at about 30 mph then it goes away. Do you recommend conducting your test first, or bringing it back to the shop? as I said it dosen't appear to be pulling to any one side, which is hard to determine as the roads are not flat and even. With the other tires on I had no problems as to pulling to one side or virbrating. I have not pulled a load yet since I had the new tires put on. Thanks |
Re: Thanks Bob H...
Thanks P.s. - if you did not request a balance, I would doubt that it was done. I would want to see the tire run true before they balance it, as balancing may mask a tire problem. |
I Phoned The Shop...
I just called the shop and they did balance the tires. I have to bring it back and they will check it out. Thanks for the help and info.
Neckster |
Bet now you,ve had the balancing re-done they,ll be ok....
Don,t forget to check the nuts after 50k or so... I know thats telling a granny how to suck eggs, but, a lot of drivers do forget :wink: |
Aherm.. Aherm... Coughing loudly......
50k To a European driver means 50 kilometres..... not 50,000 You say potahto I say potato..... :lol: |
50k To a European driver means 50 kilometres..... not 50,000 You potahto I say potato..... :lol: If you add one more letter, it becomes non-negotiable ; 50km ~~~SEE! |
| All times are GMT -12. The time now is 08:48 AM. |
