Keep in mind - the grease goes through the bushing before the thrust bearing. You should use a NLGI #2 EP grease... IMO. |
Could be worn tie-rod ends or pitman arm. Any good mechanic can find the problem easily.
dawn If you mean by "loose" steering the truck tends to wander all over the road and follow the pavement seams, try raising your steer tire pressure. I normally run 110-115 cold in my steers, and seems to help a lot.
Even though I have one, I don't think having a Frieghtliner has much to do with it....JMHO! |
