1  2  3
Page 2 of 3
Go to
-   -   FUEL LIGHT (https://www.classadrivers.com/forum/truck-maintenance/20500-fuel-light.html)
Rev.Vassago 09-18-2006 09:31 AM
Originally Posted by yoopr
only really accurate fuel gauge is a Stick.
That is if you don't have a anti theft screen and then that becomes a problem.
Or you can just plan your refuels to occur at 1/4 tank like I do. :wink:
You shouldn't run your tanks so low anyway.
yoopr 09-18-2006 09:38 AM
yeah-good way to pick up alot of Junk if your Pick ups are good.
marcel27208 09-18-2006 10:28 AM
i drive LOCAL so i try to only fill up 1 time per week! And if im wasting money at the end of every week on unecessary fuel id like to know it
marcel27208 09-18-2006 10:31 AM
i didnt know if this quote was for me? other wise i didnt quite understand what you meant :D
yoopr 09-18-2006 10:42 AM
It was a response to the Rev. on running your Fuel down to the bottom of your Tanks.
If you do that you're eventually gonna have a mess on your hands.
mrpersons 09-18-2006 01:40 PM
Whoe there Marcel, leave that gage sender alone! The way I read your post, you had about 40gl or so left in the tank when the gage read empty. Unless you like running out of fuel, I'd leave it alone. Go by the gage the way it is, and you'll be in good shape. (that's your reserve)
As far as letting the fuel get that low and picking up trash from the bottom of the tank, will not happen. This is because the p/u line for the tank takes fuel from the bottom all the time, most tanks have a "sump" in the bottom so you can get every last drop!
Rev.Vassago 09-18-2006 01:57 PM
Dirt and water will always end up at the end of the tank.
tdriver1959 09-18-2006 02:34 PM
On my truck the fuel Gage reads a little lower than what i have in it. Usually when i get a little under a 1/4 of tank i put fuel on. I used to let the tanks draw way down until i got a lot of crap into the fuel filter, and had to replace along side the road. What a head ache learned a real quick lesson on that one
yoopr 09-18-2006 03:12 PM
Yeah-OK
marcel27208 09-19-2006 10:06 AM
so are you saying that i actually did have about 40 gallons left..but thats a reserve or something?? doesnt dirt ALWAYS end up at bottom of tank?????
1  2  3
Page 2 of 3
Go to
