-   -   No heat in bunk (https://www.classadrivers.com/forum/truck-maintenance/20112-no-heat-bunk.html)
09-04-2006 03:52 AM
No heat in bunk
I have a few questions and I have a feeling they are related some how. The AC in my bunk works ok but no heat. When I opened the hood I notice two valves and I think one goes back to the bunk. They are connected to the block heater. Can someone explain what those valves are for and why they are there?
yoopr 09-04-2006 04:00 AM
Bad Thermostat?
Blind Driver 09-04-2006 06:08 AM
Open the heater valves in the fall, close them in the spring :wink:
Rev.Vassago 09-04-2006 06:30 AM
They are designed to make your A/C system work better, by blocking the coolant from going to the heating system.
BD has it right - open them in the fall, and close them in the spring.
09-04-2006 07:02 AM
Those valves are close to the engine block heater. When it's plugged in, is there an electric pump circulating the water? I understand it keeps the water at 160 degrees. I also assume this flows to the bunk heating system? Would this keep the cabin warm if the fan was turned on? Anyone have an idea how long the batteries would last running the bunk fan?
Rev.Vassago 09-04-2006 01:37 PM
Not very long.
watevr777 09-04-2006 02:38 PM
The valves are installed for 2 reasons
The heater control valves are not high tech and don't work well
by turning the valves off no water circulates so no heat in the heater core...( some the heater core and A/C evaporator are 1 unit the rest they are stacked on top of each other) some trucks have 2 or 4 shut offs ...2 one for the sleeper and 1 for the cab.. 4 two for each
Reason 2
heater hoses have A habit of leaking or getting holes in them...Mainly reason 1
As far as the block heater it will keep the water warm ....there is no water circulation
yoopr 09-04-2006 03:12 PM
Good Grief-Can't believe I forgot the Faucet handle :oops:
Maniac 09-06-2006 02:50 AM
The engine block heater barely keeps the water temp at 80 degrees, BUT that is enough to make the truck start in the winter, there is NO circulation pump on the block heater.
As far as the batteries lasting with the fan on, maybe 3 to 4 hours.
09-16-2006 05:43 PM
Just a follow up here. I was looking at the engine yesterday and found 2 more valves and turned them on and bingo, heat. The 2 valves I turned on before were connected to the block heater. These 2 new valves I found were buried down low connected to the water pump. Not sure what all these valves are for now?
