Originally Posted by Zombie Woof
I can't get a clear answer to this by googling it.
If I get a DOT physical from one place, but fail, can I retake a physical somewhere else?
Thanks
There are not many carriers going to let you doctor shop, most have doctors and with the new regs coming out making sure the doctors CAN actually do DOT physicals.. it's a done deal. If you are in danger of failing a DOT physical, you need to fix that problem before it along with trucking KILLS YOU along with whomever happens to have the bad luck of being near you when you do..
