11-29-2013 01:28 AM by
15265
I have a 379 peterbilt with 48 ft flat with 10 ft spread 272 wb on pete. need to go from Ohio to Fairbanks what do I need?
11-29-2013 01:43 AM by
GMAN
Do you already own this equipment? Do you plan on hauling a load or deadheading? Do you have your own authority, lease to a carrier or just need to transport the equipment to Alaska?
Permits for over length tractor wheelbase and overall length of truck & trailer can not exceed 23 meters (74' 9").
To qualify for a permit tractor with a 272" wheelbase can not have a trailer wheelbase greater than 12.1 meters (39' 8").
Combined weight on spread axle can not exceed 20,000 lbs.
Must be a legal dimension load to qualify.
11-29-2013 02:49 PM by
15265
I have the rig leased to UAC
Unless that truck is set up for extreme cold weather operation, a trip like that this time of year could prove deadly. Trucks that run up that way usually have extra insulation on EVERYTHING, fuel lines,air lines water lines, etc.
I hope it pays way better than average..............WAY WAY BETTER, other wise, leave it to someone else
Sounds great....But than you'll have to consider DH time consuming, permits,.... suddenly it's not so great, rather jus a bit better than average, and that's if all go smothly, god forbid some eqipment, or othe problems.
