Originally Posted by gorourk
can you be 160 pounds overweight on steer tires and would backing the 5th wheel back all the way help
Will the DOT give you Leeway?
DOT *might* give you leeway.
What states will you be traversing? How wide are your steer tires?
If you're in VA, 12,160 would be just fine running 10-inch-wide tires. However, other places may not be so gracious.
