Originally Posted by ironeagle_2006
Fine Beaner you do not like Reefers then here is a solution for you Stop Eating it will solve itself in about a month or less. All I ever Pulled was Reefers and the only trouble I ever had was from Skatboarders that decided that Shutting off my unit was FUN. Or the SkateBoarder that couldn't back up to save his life or the ones that had 6 Inch Straight pipes and had to use the Jakes in the TS.
or whats worse is the idiots with the 8" pipes looking for a spot jumping on the jake.. or the air dryer that keeps popping off, you idle beaner? i dont like that at all (sarcasem). a reefer running should be the least of your problems.
