Anyone out there have experience securing 60 foot lengths of rebar onto a 48 foot flatbed? I have done several loads out of Seattle now and today while loading I had the driver waiting after me asking for advise. He has a 2000 Freightliner Argosy with ~180" wheelbase and 48 foot trailer. With last 2 loads of rebar, he has had a car pull out in front him requiring him to lock up the brakes. The loads shifted and the rebar ended up against the back of his sleeper(Actually it came to rest up against his intake snorkel). He had to call a wrecker to fix the load and it cost him $400-500 each time. Apparently, he thought I may have a better method securing this type of load.
The way I loaded today 8 bundles(the bundles were stacked 5 and 3) weighing 46,000 lbs was 5 feet over the front, 7 feet over the back(5+48+7=60 feet), and used 5 pieces of 4x4" dunnage on the deck. I threw a chain over the front and back end of the trailer since my winch rails don't run the full length. I then throw 3, 4" straps over the load and 2, 4" straps I gut wrapped. I use the gut wrap method to, one, insure that the load can't move side to side. Two, if it shifts forward the strap "should" cinch-up tight stopping the movement. Since I am using 7 straps/chains, this should be sufficient to legally secure the load.
The way the shipper runs their operation is to load the rebar onto the trailer, have the driver scale, then park and secure the load. In the parking area there was 4 trucks all with 60 foot loads of rebar. The driver with the Argosy, myself(2001 Peterbilt 379 with 315" wheelbase; I have almost 10 feet of catwalk between the back of the sleeper and the front of the trailer!), and two other drivers were all discussing the best way to secure(I think there were at least 5 opinions :-) ). Several like to build up their dunnage 2 or 3 high on front to liftup the rebar allowing it to clear airlines and stuff on their catwalk(my truck has the airlines/electrical connection at the rear of the truck and under the trailer so the catwalk is completely unobstructed). Some were using 4-6 chains and 2-4 straps. Everyone except myself was gut-wrapping the chains or using a "modified" gut-wrap like a leash(the chain was wrapped around the load, 1 hook hooked to the chain itself and the other hook attached to rub rail).
I thought all the methods used were good and legal, but I don't know if any would have stop the load shifting forward in a panic stop the way the Argosy driver described. So, my question is there something the 4 of us missed? If you have an opinion, please reply(Yes, I know the adage that 1 more strap/chain can't hurt).
