Originally Posted by firebird_1252
yes the rocker assembly has to be removed? aparently i have a broken valve spring on the same cyl i just did the injector in. there was a tick in the motor.. they said it was the valves out of adjustment. they test drove it the tick came back. turns out they removed the rocker assembly and they found a broken valve spring. same cyl the injector was done.
Sorry...my bad......Yeah...remove the rocker assembly to check the springs.
Did they charge you for the broken spring? It should have been on them....IF they had done the injector.
