A couple days ago I noticed and audible air leak coming from my air compressor. I’ve been noticing over the last few months that at times I seemed to be losing air, but could never pinpoint the problem component. After starting and idling the truck for just a few minutes, I noticed the fairly loud leak and upon further inspection, I found where oil had apparently been blown through the side of the compressor head and onto the engine.
I called Peterbilt and they have a rebuilt compressor for under $1,000 (with exchange, of course). They also offer a seal replacement kit for around $150. The question is, should I replace the whole compressor or just the seals and gaskets and hope that solves the problem? The truck has about 765k miles on it and around 17k hours. I’m thinking that it would be less work to replace the whole thing than to take it off and open it up. I’ve never done either, but with instructions, could do either job, I’m sure. The secondary issue is with that many hours on the compressor, is it worth simply replacing seals and gaskets, or am I just prolonging the inevitable for a while?
