I’m surprised that there isn’t more discussion amongst the open deck trailer types about these simple, yet nearly essential pieces of equipment. I know I can buy them at most pipe yards, but like most things, I prefer to make my own if I can do it cheaper and come up with a better design. I know I can simply cut lengths of steel channel or tubing, but has anybody out there added any extras? I was thinking about using heavy gauge tubing and then welding a couple tabs flat to the pipe so that it stops the pipe from falling through the stake pocket and allows two inches of stake to protrude from the bottom of the pocket. Then drill a hole though the sides in the bottom two inches and using either spring loaded positive locking pins or the old wire locking type to prevent the stakes from bouncing out of the pockets.
My next question is regarding laws in various jurisdictions. I’ve read, maybe even on CAD, that not running a strap or chain across the tops of adjacent stakes in Texas is an unforgivable and costly mistake. Is this correct, and are there and other states that have peculiar regs governing pipe stake use? Is either securement method acceptable? Must the tops of the stakes be secured, or can you simply draw the pipes together as the bottoms with a chain or strap run under the load? What are the various ways folks have come up with the secure the stakes? What size straps or chains are mandated?
Any input (especially if it’s creative and you’ve personally used it with success) will be greatly appreciated.
