Originally Posted by firebird_1252
wish i had a kw.. it wouldnt handle like a damn barge ... anyway no its a 04 columbia. the tires are going from low pros to regular 22.5's. if HUGE if i land this work i'm dropping the gears to 3.55s. when i do the tires i'm getting 6 alum. wheels.
What ratio do you have?, don't be so quick to change the ratio, it will be around 4 grand and might not do a whole lot, aluminum wheels are 60 pounds each, the steel ones are 90 pounds, not much weight to be saved, but they do look better, and will last longer
