-I think the adjustable deck height is alot od expense and weight for nothing. What exactly is the problem with the trailer you have now as far as height goes?
-Can't you pull a Landstar RGN and pay the fee to them like the van guys do?
-It's not really that limited. Does LS not go into Dundalk? BTW, if you don't have a TWIC you may as well forget about an RGN.
The adjustable deck height is about $150 and weighs about 1 pound. It is just a bracket with holes that changes the position of the leveling valve. If you go with open wheel wells you give up having a slider so you can open and close the spread for western canada, get a 3 axle fixed and you can get covers(removable) for the wheel openings, carry a little extra dunnage and you could load steel and machinery over the wheels.Originally Posted by rank
-Well, yes the 53 was a no brainer but you made your bed.-I think the adjustable deck height is alot od expense and weight for nothing. What exactly is the problem with the trailer you have now as far as height goes?
The tri axle would make it easy to axle 80,000 lbs.
Having TWIC card is good but going to Dundalk sucks, most of the freight is cut once or twice before it leaves the docks.
If you can load toward the area where the yellow iron is then load a machine to Ca, i can hook you up with the LTL king and put an extra 1 or 2 dollars a mile out of the rust belt back to Ca.
you need the trailer that gives you the most loading opportunity.
