When is the annual 2290 tax due? I thought it was the end of june now i heard it is the end of august
06-07-2010 02:40 AM by
GMAN
This if off of the IRS website.
When To File
Form 2290 must be filed for each month a taxable vehicle is first used on public highways during the current period. The current period begins July 1, 2010, and ends June 30, 2011. Form 2290 must be filed by the last day of the month following the month of first use (as shown in the chart below). The filing rules apply whether you are paying the tax or reporting suspension of the tax. The following examples demonstrate these rules.
Example. John uses a taxable vehicle on July 1, 2010. John must file Form 2290 by August 31, 2010, for the period beginning July 1, 2010, through June 30, 2011. To figure the tax, John would use the amounts on Form 2290, page 2, column (1).
Thank You! I looked on the IRS site and couldnt find that!
06-07-2010 11:59 AM by
GMAN
You are welcome. You can either print the form from the IRS website or go to your local office to get the form. I prefer to pay it locally so that I can get a receipt on the spot. I believe that it is under forms and publications. There is a search feature on the site. Good luck.
Im only about 45 minutes from the IRS office here. When I got started last year I went there and did it. Plan on doing the same this year. I just assumed since it expires on June 30 that it was due again by June 30.
07-12-2010 03:48 PM by
HSC
2290
Also, if you google "2290 Comdata," you can file it electronically. There is a good FAQ on the site too, that answers some common questions about when and how and why to file the form
