Originally Posted by GMAN
. . I don't understand why someone can't invent a charging system that will charge batteries while traveling down the highway.
This is a great point. I . . (que the harp music) . . I drift back to my youth when we had bicycles and little electric motor/generators with a rub wheel which, when secured against one of the tires, would power the lights. I'm not making a direct comparison but it seems to me that there's a lot of untapped potential energy on every truck.
And then there's solar and wind. The equipment is both lighter and more efficient than ever. Why isn't there a fan somewhere on the front of my truck and why isn't there a solar panel on the roof of every trailer? It seems, to this simple mind, that we should be powering the truck stops through a "reverse idleaire" instead of the other way around.
As to the economics of the eStar, in round numbers, 100 miles translates to 12 - 15 gallons of fuel or $36 - 45 dollars at today's prices. No matter how you run it, that's a substantial savings or quick payback, less charging cost, on the $150k (an early production speculative number). I don't see these things being used as road tractors for awhile, at least. I'm thinking more in terms of medium to heavy, short haul crew and maintenance trucks.
