Originally Posted by solo379
Wow! And not the other way around? A you sure?
I don't have personal experience with C-13, but it's a CAT! Should do just fine! If everything else is OK, just grab it!
Yes I am sure. I don't know about dump trucks, but any over the road tractor with a CAT will be thousands cheaper than the exact same truck with the same miles with a Detroit or a Cummins. This is because CAT is exiting the truck market, has a very bad reputation for reliability, and is known as a the worst engine for fuel mileage. All of this is bad enough, but the C13 has a history of actuator problems that are extremely problematic.
Still, a Mercedes is even worse. The same truck with a Mercedes is $19,000.
