Originally Posted by Flyerfan4life
Afternoon all another question from the newbie. At school we had to learn to shift gears via doubleclutching and wouldnt let us learn to float. We were given 1300 rpms for low gears and 1600 rpms for high gears and down to 1000 rpms to downshift. What is the difference via floating ? Do you get to proper rpm for gear than lift on the throttle to push to gear than back on the throttle ? Any help is greatly apprecited I head to orientation in a little over 2 weeks.
There is a certain RPM that you can take the truck out of gear without using the clutch. Likewise, there is a certain RPM that you can put the truck back into gear without using the clutch. That is what "floating" the gears is. Each truck is different at what speeds and rpm's it will do it at, and the only thing that will teach you how to do it is time and practice.
