Originally Posted by Flyerfan4life
Thanks a bunch folks ! I am really learning alot from this site and its members. What I typically do when downshifting as a newbie I try and atleast get down to 7th gear stop flip the switch to low go to neutral than back to 7th which now will be 2nd and start from there again. What is the difference between a normal 10 speed and a super 10 I dont think I have driven super 10 yet.
"Normal" 10 has 5 low, flip the switch 5 high. Super 10 - no low/high switch - split shift. 1/2 in one position - start out in 1, hit the switch and let off the fuel (or stab the clutch to release torque) the tranny shifts to 2 (without moving the stick). Move the switch back, double clutch (or float) into 3, move switch break torque and it shifts into 4. You get 10 gears with 1/2 the movement of the stick - as each physical shift has 2 gears.
They're fun to drive, less tiring (less stick movement), easy to get confused and lose track of where the hell yer at gear-wise. My instructor called it "the thinking mans" transmission. You can do a 2 gear downshift with one move of the stick (don't forget to rev). Think of the switch as an odd/even switch and it's easier to figure where you're at. Only 4 guys in my class (of 12) even felt like trying it out - the rest had enough problems shifting ANY transmission. You don't see them on new(er) trucks, I had a lot of fun driving it.
As others mentioned, you don't want to be floating for your road tests (state or company). Just shift the truck with the clutch, be smooth, and don't coast. Turns (at least where I went to school) have to be done in low range. If you're in 7th, drop down to 7-800, clutch into N, clutch out, rev up to 1,600, clutch in and "loop" into 5th (don't forget the low/high switch). You can't ALWAYS get a red light at a turn (much as we like to PRAY for them in school during road testing). You MUST develop the skills to keep the truck in the PROPER GEAR for your road speed/RPM. Lugging/over-revving is a NO-NO.
Rick
