Originally Posted by Cueball
Haven't been able to find an answer to this. Does any know or have they heard, once you have your prints taken, and receive the letter back. How long do you have to add your haz mat before you have to worry about being fingerprinted. I have a friend who had has prints done and passed the background check but never went back and reinstated has haz mat. Under this situation, how long is that background check good for before you have to go back and do it again (the prints)? I did mine, paid the money and added the endorsement even though I ended up not taking the job I needed it for. I figured I paid the money I might as well add it.
From
TSA | Transportation Security Administration | U.S. Department of Homeland Security used "hme" in the search block:
Q: How often must a driver be fingerprinted and qualified under this rule?
A: Generally, you must renew your HME every five years, although some states may require more frequent reviews. You will be required to submit new fingerprints at the time of renewal of the endorsement.
From
Federal Motor Carrier Safety Administration
§384.233 Background records checks.
(a) The State shall comply with Transportation Security Administration requirements concerning background records checks for drivers seeking to obtain, renew, transfer or upgrade a hazardous materials endorsement in 49 CFR Part 1572, to the extent those provisions impose requirements on the State.
(b) The State shall comply with each requirement of 49 CFR 383.141.
Be safe
