I am selling my 02 INT 9900I. Things slowed down and with no improvement in the near future, I decided to accept a management position with the WV Dept of Transportation. That being said, here are the details:
2002
International
9900I 72" High Rise Pro Sleeper
C15 - 500 HP
3 Stage Jake
13 Speed
3.73 Rears
11Rx24.5 Virgin Rubber
Aluminum Rims (Front Axle Only)
554,000 Miles
Here is what I have done to the truck since I purchased it:
Overhead run 97,000 miles ago
New Shocks
New Mattress
New AC Compressor and dryer
New Belts
New Exhaust from the Turbo back
Raised 5th Wheel Currently set at 53.5 inches
New Product pump 3" inlet and outlet
Air Compressor
Hose Rack
New Clutch and resurfaced flywheel
Espar Bunk Heater
1500 Watt Inverter
I have put 97,000 miles on the truck since I purchased it. I serviced the truck every 15-17,000 miles and lubed the chasis between oil changes. I also had an oil analysis done with each service. When I raised the 5th wheel, I put blocks between the frame and the 5th wheel mount, so it would be easy to respec to flatbed or box trailer specs. I installed the Espar bunk heater about 3 months ago.
Fuel mileage has ranged from 5.5 from Nitro, WV to NJ and 6.5 running to TX or FL. This is pulling a tank with a gross weight of 79-80,000 and a road speed of 65-70 MPH.
PRICE: $30,000
I will post pictures this weekend
If you have any questions my cell is: 304-932-8214
