Originally Posted by lowrange
I've had it before, I think it's the starter going out, or is it the batteries? You know, you're cranking the truck but it bogs down for a second or a split second before it cranks.
The obvious first check is for loose connections in the starting system.
But, I would start with this; measure battery voltage before and during crank. If you can do this... report back ; )
