Originally Posted by NotSteve
Originally Posted by charged
For example load A weighs 5K lbs and load B weighs 48K lbs.
Your tractor/trailer gets 20% better gas mileage unloaded than fully loaded on regular flat land.
Do you accept a lower than normal rate? Or do you demand the same rate as a heavy load?
Doesn't matter what the weight is and you can bring up all the statistics you want about needing more money for the heavier load. The broker knows what they are going to pay and if you don't want it, they will move on to the next truck until they get desperate.
I've talked to lots and lots of brokers. I have never been able to get one to move on their. Most have a stated rate which is usually a per job rate. There are a few that don't have a rate and want you to give them a rate. I've only have one ever say their rate then in the same breath say she had more in it.
I've asked for more, but have never got it.
There is a lot that goes into it. Looking at maps to make sure the miles they are paying you for are not short miles on small highways through mountain ranges. Looking for toll roads that eat up your money. Making sure you can get a load going somewhere else once you get the destination. Endless calling for jobs that are already gone and the broker was too lazy to pull.
:rock:
