Originally Posted by ironeagle_2006
How about that 9 over that Eaton had were your pattern was Granny First second third pull the spiltter then back to grandma then run the rest. However if you forgot about 9th was OD only and shoved it down into what would normally be 4th in anyother trans you would hear this nasty grinding.
Ummm.....That's a standard 9 spd. :roll:
If you actually used the granny gear on the highway, you are an idiot. That's not a highway gear. :roll:
