So there has been some active discussions regarding my generator system that I've been building for my truck. As promised, here are some pics of it.
The box is made of 1/8" steel, and is bolted to the frame in six spots.
There is a double door that splits in the middle.
With the top open, everything inside is fairly easily accessible. The generator is bolted directly to the box, which is lined with sound deadening material. More sound deadening material will be added tomorrow (I ran out).
There is a 12V radiator fan in the rear which moves 500 cubic feet per minute. There are two vents - one on the left side, and one on the right.
The exhaust runs the entire length of the frame, and exits out the back.
I removed the fuel tank already, and Peterbilt will be running fuel lines to the generator for me on Monday.
I have a little bit of work to do tonight, and I'll take some pics of the A/C system.
Any and all criticism on this build is welcome. As I am flying blind here, if you think I've done something incorrectly, by all means - point it out.
