Some of the older 12 volt receptacles where rated 15 amps, I don't know if the newer plastic ones can handle the 15 amps. If it has a 15 amp fuse in the fuse box it will.
But the weak point is always going to be the the actual 12 volt plug on the item. The cheap ones are known to melt at around 12 amps. Heavy duty plugs will do the actual 15 amps continuous. They are made of heavy plastic that can handle the high temperatures.
More details
