But the biggest is efficiency. I would NOT spec a 10 speed overdrive, I'd rather just go with a 13 speed (they're all overdrive).
That specific ultrashift, or the I-shift are both direct drive. Saving about 2-3% in fuel. That's a lot of dough.
All Schneider trucks are direct drive.
Here's what I said on another forum, explaining the specs in more detail:
Of course these specs can be tweaked, but I assure everyone here there's a reason for every choice. For example 2.64 gears with a direct drive transmission will get you about 3% better fuel mileage, saving you thousands every year.
Haldex "lifeseal" brake chambers because the springs inside are completely sealed from the environment, since switching I have not had a problem with a brake chamber. Usually they last no more then 2 years up here.
Rack and pinion steering for the Cascadia due to the better handling.
Disc brakes(even though they're $4000 more) better braking, way less brake fade, less maintenance, no greasing, higher resale value etc..
Amboid differential gears vs. the usual hypoid(which is what 99% of trucks out there have) because of better driveline angles, less vibration, stronger diff units, less chances of leaks(since the seal is higher on the diff) etc... the salesman said meritor just released amboid diffs, and he's pretty sure hypoid won't exist in a matter of 2-3 years.
XZA3 steer tires because everyone I talk to seems to think they're the best. I got nearly 250,000 miles out of mine.
XDA energy tires because they're the most efficient drive tire that isn't a super single.
XDA x-one (NOT XDA-HT) super single tires because they are the most efficient tire ever made.
Delco remy 36SI HP is probably the best alternator money can buy, these things are VERY tough, very efficient, and can handle the heat. They also have "remote sense" that bumps up the voltage if there's a big voltage drop over the batteries(when they're charging a lot).
That front axle for the Cascadia to allow rack and pinion steering, and because it has ROLLER kingpins. No other axle I know of comes with that stock. Sure you can get kaiser aftermarket, but that's no fun.
What's funny is the Volvo sales guy knew his stuff, but I was teaching him a lot more then he was teaching me. Maybe I should be a salesman. The Freightliner guy seemed sort of clued out about some of the stuff.
