Originally Posted by Malaki86
Originally Posted by rank
I agree that the truck + trailer need to be level to get an accurate reading.....but as for the other stuff.....well I've charted ~100 readings on CAT scales in winter and summer and I've noticed no inaccuracies.
Cat scales don't use air pressure to measure the weight. They use load sensors which are basically a piece of metal that gets "squashed" when you drive on them. The computer reads the "amount of squashing" to give the weight.
Um, yeah.
What I meant was, I've scaled a bunch of loads and also taken the pressure gauge readings on each axle for those same 100 loads. i.e 80 psi on the rear axle of trailer = 40,000 lbs. Then I made a chart using all these loads so whatever the psi is, we can get a pretty good idea what the axle weights are. If it's sitting level.
