Went and got the truck today after having the GPS system put in. Had a driver in the car with me to put him in the truck and then I see it wasn't running right and black smoke was coming out of the stack. So in the shop it went. First real problem I've had with the truck since warranty ended.
Anyway from my laptop I can zoom in and see on Google maps where the truck is, speed, trail etc. But I paid extra and got the PerfromX cable and this is the first report I generated from my laptop:
Earliest reading 04/07/2008 16:00 n/a
Latest reading 04/08/2008 13:00 n/a
Report duration 20.99 hours n/a
DISTANCE/FUEL
Odometer 137502.5 to 137523.8 n/a
Total Distance 21.3 miles avg 24.4 / day
Total Fuel 4.875 gallons n/a
Average MPG 4.37 miles/gallon n/a
Average Speed 33.0 mph n/a
TIME BREAKOUT
Engine Time 1.34 hours 6.4%
Moving Time 0.65 hours 3.1%
Over RPM Time 0.00 minutes 0.0%
Over Speed Time 0.03 hours 4.7%
Excess Speed Time 0.00 hours 0.0%
IDLE BREAKOUT
Long Idle Time 0.32 hours 23.7%
Long Idle Count 2 avg 9.49 mins each
Long Idle Fuel 0.332 gallons avg 0.17 gals each
Short Idle Time 0.37 hours 27.9%
Short Idle Count 23 avg 58 seconds each
Short Idle Fuel 0.424 gallons avg 0.02 gals each
PTO BREAKOUT
PTO Fuel 0.000 gallons n/a
PTO Time 0.00 hours n/a
The fuel average was horrible but probably cause it was burning fuel. Pretty amazing this thing though. This truck had a new ECM installed before I bought it so I guess that's why it has so few miles on the ECM.
Here's some more info I pulled off. It looks better on the screen but to copy and paste it isn't as nice. Once I get the truck going I will post more of these. The guy didn't put on the trailer skirt like he was supposed to but even better cause now I can run it and then put it on and then see if the change is obvious. Any other things anyone would like me to try let me know.
COST / SAVINGS MATRIX
Distance Traveled 21.3 miles
Fuel Consumed 4.875 gallons
Actual MPG 4.37 miles / gallon
MPG Goal MPG
Fuel Wasted 0.62 Gallons
Your fuel cost per Gallons
Waste at your fuel cost
($1.50 / Gallon) $0.92
Waste at the national average cost
($3.96 / Gallon) $2.44
How MPG Cost is calculated
The table above compares your vehicle(s) MPG to a goal you have set. Being above this goal means you consume less fuel which translates into lower cost. Being below this goal means you consume more fuel and spend more money.
During this report period your vehicle(s) consumed a total of 4.875 gallons of fuel over 21.3 miles averaging 4.37 miles / gallon.
Your MPG goal was 5.00 MPG. With this goal 4.260 Gallons of fuel would have been required to travel 21.3 miles. Your actual fuel usage was 4.875 gallons, so you used 0.62 extra Gallons of fuel.
Your fuel cost is $1.50 per gallon. The current national average fuel cost is $3.96 per gallon. You spent an extra $0.92 and $2.44 at the national average fuel cost.
Idle Time vehicle 89362 (Vehicle 89362)
Idle Fuel Rate Gallons per Hour
Short Idle
Short Idle % 27.9%
Short Idle Goal %
Time Over Goal 0.36 hours
Extra Fuel Consumed 0.18 Gallons
Loss at your fuel cost
($1.50 / gallon) $0.27
Loss at national average cost
($3.96 / gallon) $0.71
Long Idle
Long Idle % 23.7%
Long Idle Goal %
Time Over Goal 0.18 hours
Extra Fuel Consumed 0.09 Gallons
($1.50 / gallon) $0.14
($3.96 / gallon) $0.36
How Idle cost is calculated
The table above compares your vehicle(s) short and long idle times to the goals you have set. Being below these goals means you consume less fuel which translates into lower cost. Being above these goals means you consume more fuel and spend more money.
Your short idle goal is 1.00 %. With this goal you would have short idled 0.01 hours during this report period. Your actual short idle time was 0.37 hours, so you exceeded your goal by 0.36 hours.
Your fuel cost is $1.50 per gallon. The current national average fuel cost is $3.96 per gallon. You spent an extra $0.27 and $0.71 at the national average fuel cost.
Your long idle goal is 10.00 %. With this goal you would have long idled 0.13 hours during this report period. Your actual long idle time was 0.32 hours, so you exceeded your goal by 0.18 hours.
Your fuel cost is $1.50 per gallon. The current national average fuel cost is $3.96 per gallon. You spent an extra $0.14 and $0.36 at the national average fuel cost.
Revenue Estimate vehicle 89362 (Vehicle 89362)
Moving % 3.1%
Moving Goal %
Time Below Goal 6.70 hours
Distance Below Goal 220.76 miles
Deadhead Percent %
Deadhead Distance 22.08 miles
Lost Revenue Distance 198.68 miles
Revenue per Mile $
Lost Reveue $99.34
How Revenue Estimate is calculated
The table above compares your vehicle(s) moving time to the goal you have set. If the moving time is greater than the goal, that vehicle(s) is generating extra revenue. If the moving time is less than the goal, that vehicle(s) is not generating the expected reveune.
Your moving goal is 35.00 %. With this goal your vehicles would have been moving 7.35 hours during this report period. Your vehicles were actually moving 0.65 hours which means you fell short of your goal by 6.70 hours. During the report period your average speed was 33.0 mph. At this speed your vehicles would have traveled an extra 220.76 miles in 6.70 hours. If you are deadheading 10.00 % of the time then 198.68 miles would have been revenue generating.
Your revenue per mile is $0.50 for a total of $99.34 in lost revenue.
Over Speed vehicle 89362 (Vehicle 89362)
Over Speed % 4.7%
Over Speed Goal % %
Time Under Goal 0.00 hours
How Overspeed is calculated
The table above compares your vehicle(s) overspeed time to the goal you have set.
Your over speed goal is 5.00 %. With this goal your vehicles would have been over speed for 0.03 hours. Your actual over speed time was 0.03 hours. You were over speed 0.00 hours less than your goal.
