Its a never ending load of garbage every single time I let somebody else touch my truck.
When they put the truck back together,..the speedometer, cruise control were not working (they smashed the end of the sending unit) and they didn't tighten the bolts that hold the carrier bearing cradle to the frame. One bolts was missing, the cradle was hanging on by the other loose nut/bolt,.. I was 20 miles down the road when I noticed a noise that I felt shouldn't be there. I went back to the garage and told them what was happening and they fixed the speedo and cruise control, but the vibration was not fixed,...There were two mechanics trying to figure out the vibration,..and they couldn't"t figure it out. I asked them if I could use their creeper to go under my truck. In less than 10 seconds I found the carrier bearing cradle is what was causing the problem. The drive shaft was two turns of a nut from falling out and destroying my truck,that was stopped because I found the problem,... but,the drive shaft being out of alignment ruined the new transmission.
The garage owner actually had the balls to tell me that rebuilt transmissions all make that grinding noise :roll: , and that it will go away after a few thousand miles. I just looked at him and had no response to such BS. After 5 hours of BS he decided to R&R.
So,.....here I am sleeping in my truck outside the garage and they are putting another transmission in tomorrow, and I am going to watch the entire process this time,..they're not happy about my being there,....but I'm not real pleased with their incompetence,...so as far as I can see,....we're even, and I'm not letting my truck out of my sight ever again!!!
