Originally Posted by Malaki86
Well - it runs now - sort of.
I forgot to bring my gps receiver home with me, so I can't do a whole lot with it. Seems like not having a receiver attached causes it to crash. I might run to the truck tomorrow and grab it to see if that's the problem with it.
Well,
We've been shipping the CoPilot Truck 11 for about a week now. The first thing that I did was install it on an XP machine
and a Vista machine because I wanted to check the install process and the compatibility problems that we had in the past with Vista. Both installs went flawlessly. The Vista machine is running a 32-bit version of Windows with an AMD 64-bit dual-core processor with no crashes. (1 gig of RAM.)
As far as the program, it did indeed get a whole re-write. The screens are bigger and they made everything with "left-clicks" and there is no "right-click" functionality now. The maps are updated, but with any GPS, if I look hard enough I can find roads that are mislabeled or missing. The POI's are working fine also.
The truck routing feature appears to be improved and works well as long as you create yourself a custom profile in the program and identify which roads you want to "favor" and "avoid." If you don't make sure to turn on "53-foot and National Network" routing and then choose which types of roads that you want to "favor and avoid" then it won't keep you away from low bridges and small streets, etc.
As far as bugs that I have found so far, the only big one is that it doesn't run at 1440 X 900 resolution. Setting your screen to anything lower than that makes it work fine. They report that the patch is already underway for this bug.
Regards,
Don (from
www.dieselboss.com)
