Originally Posted by AlexJ81
how much weight per axle?
That depends on the axle configuration.
You can have up to 20,000 lbs on the steer axles if it and the tires are rated for that much. Most trucks however are more in the area of 12,000 lbs.
A single rear axle is 20,000 lbs
Tandem axles less than 10 feet apart is 34,000
Tandem rear axles more than 10 feet apart is 20,000 per axle.
