Originally Posted by codered
Hi there, just got hired on to drive quad axle. I am not sure what the quad part is. What do they do?? I drove tandem for a few years, so I never had to worry about them. When do you put them down? Any help is appreciated!!!!
Also, any pointers????
I see you're from WI.
In the past, some WI quad axles had one lift axle in front of the drives and one lift axle behind the drives.
Nowadays the vast majority of WI quads are being set up with the two lift axles in front of the drives, also all of the new quads are now being equipped with self steerable lift axles.
In WI the lift axles can each legally carry 10,000 lbs, the front steer axle can carry 20,000 lbs, and the drive tandems can carry 34,000 lbs. for a total of 74,000 lbs., however the maximum legal gross weight for a quad axle in WI is 73,000 lbs.
There are seasonal exceptions to this gross weight limit for hauling certain materials,(with the proper permits) but basically just keep it at 73,000 max.
Lift axles must be down with the proper amount of air pressure applied to them whenever the truck is on the road with a load on.
If your truck has the older non steerable lift axles you must release the air pressure from them when turning a corner, or you will be unable to steer and the truck will try to go straight.The tires on the lift axles will also be severely worn and scuffed if you attempt to corner with the axles down.
You must remember that the lift axles are equipped with brakes, so the trick is to approach the corner, use the brakes to reduce your speed to an acceptable level for the corner, then get off the brakes and lift the axles just before you start to turn.
If you raise the axles while you are using the brakes, as the air pressure is released from the axles the wheels will lock and skid, leaving black skid marks, making squealing noises, and making your boss irate when he sees the flat spots on the lift axle tires.
Also remember to lift the axles when you arrive at your destination, before backing in to dump.
If your truck has self steerable lift axles, those are much easier to use.
When you're truck is loaded and you enter the road, put the axles down and leave them down until you get to your destination, then raise them when leaving the road.
Most self steering lift axles are set up to automatically raise whenever the transmission is shifted into reverse, in case the driver forgets.
(Trying to back up with steerable axles down causes the wheels on the lift axles to max out in one direction or the other, not good for the axles and makes it tough for the truck to move in soft ground, hence the reason for the reverse lift thing)
And as stated previously, make sure the lift axles are down whenever you're on the road with a load on, or else if you're stopped by a cop they will weigh the truck as a tandem, and you will be paying a big fine! (In the thousand dollar range)
The boss will not pay that type of fine, because it is
your responsibility to operate the truck properly and be sure the axles are down.
