Well I found a company that will compensate most of my driver needs.
BTW inmate 1577 when loading and unload or on breakdown, surfing the net or taking nap, i will be doing the same thing, But getting paid here
here is there compensation package, keep in mind i am Canadian.Effective Jan 1, 2007
MILEAGE
Mileage rates: Canadian Miles: $0.38/Mile
USA Miles: $0.42/Mile
PICK UP & DELIVERIES
Full Load Customer
1st Stop $34.00
Each additional Stop $14.00 each
The following would not qualify to be paid as a full load customer stop,
If the driver is performing P&D work directly for a Terminal, the driver will be compensated on an hourly basis at the following rate.
Hourly Terminal P&D - $15.76 per hour Atlantic Canada
Hourly Terminal P&D - $21.87 per hour Ontario
Hourly Terminal P&D - $17.50 per hour Montreal
Hourly Terminal P&D - $18.03 per hour Québec City
Terminal Wayfreighting
These rates apply whenever making an enroute drop or pick up at a Terminal location and you continue on to your final destination with the same trailer
$21.87 per hour - minimum ½ hour
MECHANICAL BREAKDOWNS
The driver will be entitled to be compensated for a delay incurred that is a direct result of a mechanical breakdown of the equipment. The compensation will be as follows;
Per hour rate payable from time of breakdown - $15.00 per hour
Maximum of 8 hours per 24 hours
OTHER HOURLY COMPENSATION:
Pick up and delivery Delay:
Drivers performing live pick ups and drops will be compensated after 4hrs at a rate of $15.00 per hour. If driver expects pick up or drop cannot be completed within 4 hrs, you must contact central dispatch after 2 hrs so we can try and rectify the issue. If you fail to contact central, you will not be compensated.
Tropicana: For delays at Tropicana only, you will be paid after 2 hrs from scheduled pick up time.
Initial Dispatch Delay:
Any delay (dispatch or company equipment) that prevents you from attaining miles at your scheduled start time will be compensated at $15.00 per hour for every hour until departure.
Excessive Terminal Delay:
Any delay at a terminal that exceeds 12 hours will be paid at a rate of $15.00 per hour for each hour until dispatched.
NOTE:
None of the delay payments are applicable if the cause of delay can be considered "ACT OF GOD".
Example: Extreme weather, power failures.
REQUIRED TRAILER WASH DELAY:
1 hour will be paid to drivers required to stop and wash trailers while on the road.
Dispatch must be advised prior to having trailer washed.
LAYOVER ALLOWANCE
USA Layovers:
Driver will be compensated a flat rate of $150.00 if you do not receive a dispatch within 12 hours from time you are empty and available for reload.
BORDER CROSSINGS:
Drivers will be paid an allowance as follows for clearing loads at the Canada/USA border.
Southbound-$5.00 per shipment Maximum $50.00 per load.
Northbound-$5.00 per shipment Maximum $50.00 per load.
NY CITY BONUS:
Drivers dispatched into one of the five (5) boroughs of New York City will receive an allowance of $150.00.
The five (5) boroughs are Brooklyn, Bronx, Queens, Manhattan, and Staten Island.
SAFETY BONUS:
Each driver is entitled to receive a $0.02/mile quarterly bonus on all paid miles.
To receive this bonus, the driver must comply with the following:
Have no preventable accidents for the quarter.
Comply with the company uniform policy for the quarter.
