Originally Posted by Malaki86
Don't know if this would count as a true savings plan, but this is one way I set money aside.
Anytime I buy something, I pay cash. No matter what the amount is, I only use bills. The change goes into my pocket, at the end of the day into a cup, then when I get home I dump the cup into a 5 gallon jug.
Even if I buy something that is, say, $12.01, I'll hand the cashier $13.00 and pocket the $0.99 for depositing into the jug eventually. Even if I've got a pocket full of change, I only pay with bills.
One week, 5 days, I had over $50 in change that I put into the jug.
BTW - that 5 gallon jug is about 1/3rd full now and can barely lift it. I can't wait to see how much is actually in it.
This is better than saving no money at all. The only problem I see with it is the dollars inherent propensity to lose value over time (or a curve). The so-called "under the mattress" savings plan has it obvious short comings. It works fine if you are planning to save up a small sum and then buy something with that that is an asset and not a liability. An example of an asset would be to buy your own big rig, which you could make more money with being under your own operation. An example of a liability would be a nice sports car which looks nice, might get you more dates but in the end is liability (money is always going out, not in.)
The only way that the under the mattress savings plan works to your benefit is to not wait too long to purchase an asset with it. Otherwise you will be working harder to save more to buy less. Whereas the quicker you are able to save up and buy the asset (invest) the wuicker you will see a return on your money and hopefully a big enough profit that not only sustains you in the future but allows you to buy that sports car as well.
However, stashing money away today with no appreciation on its value in hopes of amassing enough to sustain your long term future needs is problematic. Your money does not keep up with inflation nor does it mantain its current market buying value. The longer it stays under the mattress the more it losses its value and the less it will buy in the future. So, if you can invest your savings safely (not always so easy to do) with little or no risk you can at least maintain your moneys current market buying value.
