If your 4-ways work then your flasher is good.
And if the lights work when in the 4 way mode, then they must be wired correctly, no?Originally Posted by SteveBooth
My guess is that you wired the new lights up wrong. You can wire those lights up so you get different results as in one thing working and something else doesn't. I just went through this on my truck replacing the directional lights.If your 4-ways work then your flasher is good.
LED's are polarity sensitive and if hooked up wrong they will not function at all.
I stand by my statement that the LED lights are not drawing enough current to cycle the stock flasher when the turn signals on one side are activated.
When the 4 ways are activated, then the total current draw is apparently enough to cycle the flasher due to the fact that twice as many lights are activated.
We've had this happen in the shop at work just a few weeks ago.
