Shift into top gear...eh...before you drop into the lower gear. That will slow the gears down for ya.
Huh?????
When stopped and trying to get in gear with the clutch brake not working, it's always easier to ease (grind) it into LOW gear initially, then once you've done this to stop the gears, shift the stick into 2nd or 3rd or whatever gear you're going to start off in.
