the tip had some fresh oil on it...
i only drove it for like a half mile than i parked....
speedo works...
couldn't really go far because of the weather....
hope that oil on tip isn't an issue?????
is it possible to see the tip of the sensor after it is installed? i'm guessing NO. if this is correct than the sensor is threaded into the tailshaft housing and runs in an oil bath... normal. Originally Posted by KAIMIKAZEE
well finally pulled it out...the tip had some fresh oil on it...
speedo works...
if it leaks, you can thread it back out and install a new gasket
