Q: Who is required to register under the IRP?
A: According to the Plan under section 204, all apportionable vehicles, which means any vehicle except for recreational vehicles, vehicles displaying restricted plates, city pick up and delivery vehicles, buses used in transportation of chartered parties, and government-owned vehicles, used or intended for use in two or more member jurisdictions that allocate or proportionally register vehicles and is used for the transportation of persons for hire or designed, used or maintained primarily for the transportation of property and:...
1. is a power unit having two axles and a gross vehicle weight or registered gross vehicle weight in excess of 26,000 pounds or 11,793.401 kilograms; or
2. is a power unit having three or more axles, regardless of weight; or
3. is used in combination, when the weight of such combination exceeds 26,000 pounds or 11,793.401 kilograms gross vehicle weight.
Trucks and truck tractors, and combinations of vehicles having a gross vehicle weight of 26,000 pounds or 11,793.401 kilograms or less and buses used in transportation of chartered parties may be proportionally registered at the option of the registrant.
Same as the CDL and D & A testing, IRP (approtioned plates) is driven by GVWR not gross weight.
Log book, medical card, periodic inspection all kick in at 10,001 pounds or more in interstate commerce.
A two axle truck shouldn't have to deal with IFTA as IFTA kicks in with three or more axles or 54,000 pounds.
Be safe.
