Originally Posted by csramsey640
OK, same here. How do you go through pulling codes on yours? I tried fooling around with it, and cant seem to get them to come up. (if there are any)
Celect plus (N14) does not flash codes on the dash unless they are active (happening right now).
Not sure about century, it may be different, but normally you would turn the key switch on while holding the diagnostic (check engine) switch on, then release the switch and count flashes.
