Originally Posted by fastereddie
I just started for a new company and did a thorough pre-trip while my boss watched. He was curious why I wanted to mark and measure the slack adjusters because he said they were automatically adjusted. I said "four pumps on the pedal and the warning buzzer sounds".(straight truck with 4 axles) Turned out 1 axle was at it's stroke limit requiring re-adjustment. As this truck did not come with stroke indicators I attached tie wraps to the rod touching the chamber. I use the mounting studs as a reference of the stroke (they're about 1 1/4") If the end of the tie wrap goes past the stud it's time for a close look at that slack adjuster.
A lot of information on automatic slack adjusters seems to say such a condition you describe it would be wise to follow up with a complete brake inspection. Failure of automatic adjusters is not normal and when brakes are found to be out of adjustment it would suggest there has been a failure in the adjustment device.
kc0iv
