Im sure it clunks but probably not loud enough to hear. Have someone hold your brakes and turn the wheels from far left to far right. If the spring eye is broken you will see the spring move back and forth
The spring itself? I will try it out today. Basically, the spring shouldn't move right?
BTW, I did fix the problem. The S-cams were worn, especially on the right side. Kinda strange that the throws were EXACTLY the same, yet it pulled to the right. But it didn't "pull to the right" the same as if one slack was looser then the other, it was weird.
Well, I can't say I 100% fixed the problem. I think I did about 80%. Yup, I have compound problems! I think the springs are still kaput. Everything(and I mean EVERYTHING) on the brakes were changed.
God damn shops screwed me over. About 20 months ago, I did the front axle S-cam bushings. The list of things they screwed up:
- Right side wheel bearing seized up, causing $3700 in damage(got that money back)
- They used the same size S-cam tunnel seals on BOTH sides. The "slack" side was too big, letting crap in.
- S-cams should've been changed as well, they were in TERRIBLE shape.
- S-cam "dust covers" are missing, slack side on the passenger side, and brake side is missing on the drivers side. Can you imagine how hard it is to find these? Volvo can't even get them!
- Slack on passenger side was missing the smaller pin! I did fix this immediately.
All the more reason to justify doing all the work myself.
Well got the better half to help me out to diagnose further, and it looks like you're right. The left side spring at the front is definitely shot, the right side is questionable, but the rear of both springs seem ok. Who knows how long it was like this.
Shop said everything is ok? Hm....
Hope everything works for your truck. Did you lose the wheel when the bearings went?
No, it stayed on. I reacted pretty quick. That was the beginning of last year.
I'm beginning to think now I should've changed the bushings anyways. All they said was "it's good enough to pass safety", that doesn't mean it's good enough for me.
09-21-2006 05:45 AM by
yoopr
Just saw your Thread-Just a shot in the Dark-Have you checked to see if one of your Airbags on your Suspension might be low?
Air bags seem fine. Again I feel the problem is 90% solved with the s-cam brakes, it just seems the front axle has lost some stability it had.
A couple days ago, I hit some potholes in a parking lot on purpose, and the front left was clunking.
I'll post pics tomorrow of the movement. JAXLE, what does it take to change these bastards?
Thanks for all the suggestions guys, I really appreciate it!
The truck definitely handles a lot better then it did, both just driving and braking, but I still feel it needs to be a bit better!
09-24-2006 06:42 PM by
yoopr
why did you do that?
Trying to find out who strong your Tie Rods Are? :P
No to see if the spring bushings would clunk. I didn't ram them full speed, just enough to see if they would clunk.
