Originally Posted by mpwelsh007
OK. here's the deal. i am having an argument with another guy on classadrivers about this subject.
if you fail a pre-employment drug test, it will not go on you dac report because you are not employed by that company, hence pre-employment. he says that it will be on the dac report. i say it will not be on the dac report.
which is true?
From my own experience I will explain what I went through in regards to taking a pre-employment drug screen and failing it. I applied and went to a 3-day orientation for XYZ Trucking Co. and failed the drug screen This was a pre-employment drug screen. When I requested a copy of my DAC Report the actual failed drug test results were NOT DOCUMENTED on the actual DAC report itself. On the report it indicates to the company that administered the drug test, that if more information is needed in regards to test results, the company must fax for the info. So instead of documenting it on the actual DAC Report, it tells you to fax for the information. So either way they will find out whether there was a pass or fail.
