Originally Posted by Uturn2001
It all depends on what area you are in.
In many areas if you jump off and back on within a few miles of a scale house and do not have business on the route you took then yes it is often illegal.
In other areas it is perfectly acceptable to take an alternate route, just make sure that it does not look like you purpose for the route is to bypass scales.
I will agree with Uturn, it really depends, many by pass the scales on I-40 in West Memphis, Ar using U.S. 70. In Ca many of the locals complain about trucks by passing the scales in Santa Clarita using the frontage roads right in front of the scales, however Ca Dot says it's a perfectly legal route and there is nothing they can do about it. However in other places they will try to hang you.
