Originally Posted by classictruckman
why would you put chains on a trailer? I thought you only needed them on the drives.
Landstar posted a "2010 tire chain laws" PDF on the website. Here's what it says about the chain requirements in 4 western states/provinces:
Washington State Law requires you to carry a minimum of 7 single tire-chains, or 3 sets of dual-wheel chains and 1 single, between November 1st and April 1st when traveling the following mountain pass routes: I-90, I-82, SR-2, SR-12, SR-97, SR-410, SR-20, SR-155, SR-542, SR-970, SR-14
4 Chains for use on drive axle tires, 1 chain for use on the trailer, & 2 additional spare chains
Oregon State Law requires you to carry a minimum of 6 single tire-chains, or 3 sets of dual-wheel chains, when inclement weather persists (there are no set dates).
4 Chains for use on drive axle tires, 2 chains for use on the trailer
Colorado State Law requires commercial vehicles, having four or more drive wheels, to carry chains to use on four wheels, between September 1st and May 31st when traveling on I-70, in either direction, between MP 133 (Dotsero) and MP 259 (Morrison).
Chains are not required on trailers.
British Columbia law requires commercial trucks, over 27,000 kg GVW, must carry chains from October 1st to April 30th.
A 5 Axle Tractor Trailer combination is required to chain the 1st drive axle with 4 chains.
British Columbia states: Cable chains not recommended for drive axles
Washington has the most stringent requirements, that's why I'm carrying 7 chains/cables now.
