Here's an interesting quote from some past articles on power and performance I found on pittsburghpower.com
The most economical and easiest filter and housing to work with is the Farr Ecolite. At 24" long and 13.5" in diameter, this filter has an amazing capacity of 1500 CFM The price is $139 and for installations you need two clamps at $15 each. The air inlet and outlet is 7" in diameter and you will have to obtain 7" aluminum piping to complete the installation. The extra clean air entering your engine will lower your pyrometer temperature and allow your engine to run as it does on a cool, damp night."
Originally Posted by Pittsburgh Power
Most truck manufacturers supply an air filter and housing with enough CFM (cubic feet of air per minute) to satisfy the horsepower of the truck when it's being built. If you purchase a used truck with a 290 or 300 HP. engine then rebuild the engine to 400 or more horsepower your air filter is too small. Almost all trucks with the air filter stuck under the hood suffer from lack of cool air. This is the new aerodynamic look with the filter under the hood. However, it is terrible for performance. Why preheat the air before it gets to the turbo? Think about how hot it is under your hood in the summer when your 3,500-lb. engine is operating at 185 degrees and your air filter is right above it. We all know what high pyrometer temperatures do to aluminum pistons. Heat and metal fatigue are a trucker's biggest enemy. If you do not own a conventional, or cannot mount your air filter out in the air stream, then mount a second filter under your hood on the opposite side of your current filter. On a cabover it's fairly simple to mount a secondary air filter and plumb it into your existing air pipe going to the turbo.The most economical and easiest filter and housing to work with is the Farr Ecolite. At 24" long and 13.5" in diameter, this filter has an amazing capacity of 1500 CFM The price is $139 and for installations you need two clamps at $15 each. The air inlet and outlet is 7" in diameter and you will have to obtain 7" aluminum piping to complete the installation. The extra clean air entering your engine will lower your pyrometer temperature and allow your engine to run as it does on a cool, damp night."
