Originally Posted by headborg
Originally Posted by TK THE TRUCKER
Are you talking about losing your satellite signal or are you using you're FM modulator through your stereo and local stations in a city are over powering the FM modulator built in to your satellite receiver ? 8)
This is an excellent question; I too frequently find FM stations over power the FM modulator----seems on some days--I'm having to switch frequencies as much as channels.<<<<<but if this was his problem--it would be obviously apparent.
There's a feature in the setup menu--where you gauge your sat signal strength & your (earth based) signal---you're suppose to trim your antenna(by aiming it- until both signal strengths match)
This radio is supposed to have the XM side completely separate from the FM side. I don't have to pick an FM freq. for the XM to come through, just switch to "XM tuner" and it comes on.TK, when I lose XM the screen will sometimes say "no signal",but this always in a metro area where one would think the signal would be strong. I 20 thru Dallas is the worst, 38 miles e/w and "no signal".
I'm no electronics expert but here's what I think: The "auto XM" feature is manufactured just a little "off" and the terrestrial stations of metro areas overwhelm this feature and it goes to "no signal". I've tolerated this for over a year and just about given up. My hope was that someone had this same problem and discovered a simple (cheap) solution. A friend had the same radio,problems,areas, went to a Kenwood system,problems solved.
Thanks everyone for your replies. After 1/1/08 I'm replacing the system. Anyone want a crappy Pioneer system???[/i]
