Tread Depth
Navbar Menu
Forums
Today's Posts
Log in
Register
Home
Truck Maintenance
Tread Depth
1
04-23-2007 08:56 PM by
tahawus
If the tire has lots of good tread in the middle but the outside near the edge is thin is this ok with the DOT?
2
04-23-2007 09:06 PM by
allan5oh
I don't know, but change it anyways.
Steer tires? Watch your toe-in and your tire pressure. I run 105 psi on the front.
Steer tires will always wear like that on a live axle, it's just the nature of the design.
3
04-24-2007 12:51 AM by
bob h
Re: Tread Depth
Originally Posted by
tahawus
they will measure at the lowest tread depth... not the highest
maybe you should run higher air pressure in your new tires?
4
04-29-2007 11:52 PM by
DragginMan
They will shut you down if 1 of your grooves is less than recommended for that axle. I have been let go with a warning before. All up to the attitude of you .VS the officer.
5
05-13-2007 10:33 PM by
Mifirewoodguy
Does this also apply on trailer tires??
6
05-14-2007 12:46 AM by
Kranky
Mifirewoodguy
Yes.
7
05-18-2007 01:29 AM by
roadranger
If you have a set back axle and/or run at max gross all the time you might find that 110PSI is what you need to run in the steers 8) .
Truck Maintenance
Today's Posts
LinkBack
LinkBack URL
About LinkBacks
