I drive local less then 150 air miles. I do not do a log book the other day i worked 15.5hrs and drove 384 miles. What are the max hours i can work in a day being local with no log book. Dawn keep your 2cents to your self on this.
First, you need a log book when you exceed 100 Air Miles from start/return point(so I am told by safety). You can drive in circles all day and do 400 miles as long as you do not leave the 100 Air Mile radius.
As for the hours:
A) YOU CANNOT EXCEED 12 HOURS IN A EXEMPT BOOK. AFTER 12 HOURS YOU NEED TO FILL OUT A LOG FOR THAT DAY.
B) 15.5. As long as you did not drive past 11 hours, returned to the point of which you started(which I assume you did), have not used the 16 hour exemption in last 7 days or since last restart, you are o.k. Just need to fill out a long for that day.
I drive local also and use a exempt book. I DO NOT work past 12 hours(my runs are short
) and do not exceed 100 Air Miles from the warehouse.
Hope that helps
