Pretty much every trailer I've ever pulled, which must be in the many thousands by now, has the feet secured to the landing gear with a pin, not a bolt. I would assume that if they are secured with a bolt, it is because repair work was done and whoever did the work didn't have a pin available. Originally Posted by matcat
I looked at mine today, all it is is a pin.
There's really nothing wrong or dangerous with a bolt being used, because there no pressure exerted on the joint. When the landing gear is lowered to the ground, the feet are designed so that they slide up and rest against the tubing of the landing gear. The pin, or bolt in some cases I guess, is only there to hold the feet onto the landing gear when they are raised.
